Amakuni - Amakuni Kizin Super : Genesic Gaogaigar
Forum dedicato ai prodotti Sentinel Co.Ltd - Flame Toy
Re: Amakuni - Amakuni Kizin Super : Genesic Gaogaigar
【Coming up next】
Probably the biggest GENESIC GAOGAIGAR in the toy history?!
Pre-order starts on 6 Feb, FINALLY!
Overseas dealer goods are distributed by D4 Toys Co., Ltd.
HOBBY JAPAN Online Shop、千值練、D4 Toys 2026年2月6日起接受訂購: AMAKUNI超機神《霸界王 ~GaoGaiGar對Betterman~》完全變形 始源勇者王 (Genesic GaoGaiGar) 88,000YEN連稅
Messaggio da Lex »
24cm a 88000 yen, ho capito bene? Mi sa che aspetterò se un giorno Pose+ ne farà uno.
Quello a fianco più piccolo è il Sentinel X Amakuni Kizin dovrebbe essere 21 cm alla testa.
A parer mio sarà sui 35 cm!
Messaggio da Lex »
Grazie del chiarimento, quindi l'altezza è riferita al modello piccolo. Così si ragiona decisamente di più e potrebbe valere la pena considerare l'upgrade del Genesic src e magari anche del Gaogaigar soc.
35 e confermo gli 88 mila yen
voltron.
Messaggio da voltron. »
Meraviglioso, se riesco a fare il preorder lo metto in collezione, S-T-U-P-E-N-D-O
https://www.youtube.com/watch?v=m9Z5GYqD_V4
AMAKUNI KIZIN SUPER GENESIC GAOGAIGAR
A new challenge for the AMAKUNI KIZIN series!
Equipped with transformation and combination gimmicks, the Genesic GaoGaiGar that is beyond ultimate is here!
The widely acclaimed AMAKUNI KIZIN GENESIC GAOGAIGAR has been revamped with a completely new sculpt and completely new design, now featuring a combination transformation gimmick!
The arrangement of all sculpting and design has been started over from the beginning, balancing unprecedented craftful beauty and intricate combination transformation mechanism.
Its overwhelmingly large size far exceeds that of previously launched items from AMAKUNI KIZIN series, and it is equipped with ultra details and numerous gimmicks throughout its body that are comparable to its magnificent size.
Die-cast parts used in the joints provide an enhanced sense of stability, and give the figure an impressive weight and presence.
Furthermore, it is the first GENESIC GAOGAIGAR toy to have a built-in “electrically driven action gimmick”, allowing Broken Magnum in its right arm, Spiral Drill mounted on its right knee and Straight Drill mounted on its left knee to rotate. The power of the actions seen in the anime is successfully recreated with unparalleled realism.
In addition, it comes with optional parts that are compatible with the new combination gimmick that appears in the tie-in comic “The King of Braves GaoGaiGar FINAL EXTRA EXPLODED EPISODE”. The various combined forms of GaiGar and Gao Machines can be recreated, allowing you to immerse yourself more deeply into the world of the anime.
Pushing the form, gimmicks, size and details to the limits, this is the ultimate finished collectible toy.
You can do it too, AMAKUNI KIZIN SUPER! FINAL FUSION, APPROVED!
grendizer73
Messaggio da grendizer73 »
Premetto che dallle foto mi sembra ben realizzato mavorrei porre delle domande spero non tanto "assurde" dato che il modellino uscirà a fine anno:
1) in che consiste la rotazione elettrica delle (o una sola) mani e delle (o una sola) trivelle ? Meccanismo con pila ?
2) Secondo voi Bandai lo farà uscire e se si pensate che questo sia migliore ? (basandovi su prodotti della stessa linea che magari avete smanettato)
3) essendo circa 30 cm alle spalle sarebbe in scala con il GX-68 che è circa 26 cm ?
Ringrazio in anticipo chi vorrà schiarimi le idee con delle risposte anche se ipotetiche
Per me già da ora modello dell'anno!
Torna a “SENTINEL - FLAME TOYS”
