LEGO Ghostbusters Firehouse Headquarters (75827) The set will be over 4,600 pieces and retail at $349.99.
Recreate iconic Ghostbusters™ scenes with the 2-story Firehouse Headquarters, featuring laboratory, living quarters, containment unit and much more. Capture the ghosts with the proton packs and restore order, or solve other supernatural cases! Includes 9 minifigures: Peter Venkman, Raymond Stantz, Egon Spengler, Winston Zeddemore, Janine Melnitz, Dana Barrett, Louis Tully, Library Ghost and Zombie Driver.
Includes 9 minifigures: Peter Venkman, Raymond Stantz, Egon Spengler, Winston Zeddemore, Janine Melnitz, Dana Barrett, Louis Tully, Zombie Driver and Library Ghost.
Also comes with Slimer, Pink Ghost and Blue Ghost.
Slide the Ghostbusters™ heroes down the fire pole into action.
Chase the ghosts and secure them in the containment unit.
Turn the librarian old lady into a scary ghost with the double-sided face and extra wig!
Run tests on Louis in the lab to see if he’s possessed!
Suspend ghosts around the building’s exterior with attachable transparent arms.
Dodge the slime oozing up through cracks in the pavement.
Accessory elements include an alarm bell, fire extinguisher, computer, phone, toolbox, tools, jars of slimes, magnifying glass, camera, camera rolls, arcade game, toaster with slime, fridge with frozen pizza, milk and cheese, and much more!
Features opening walls for easy play access.
Features over 4,600 pieces.
Ghostbusters™ minifigures comewith decorated arms.
Measures over 14” (36cm) high, 9” (25cm) wide and 14” (38cm) deep.
With walls opened out, measures over 14” (36cm) high, 18” (46 cm) wide and 14” (38cm) deep.
Firehouse Headquarters doors can open to fit the 21108 LEGO® Ideas Ghostbusters Ecto-1 inside!
Un giorno la paura bussò alla porta, il coraggio si alzò e andò ad aprire e vide che non c'era nessuno.
Cit.Martin Luther King
Re: LEGO Ghostbusters Firehouse Headquarters (75827)
Prima o poi la prendo! Troppo bella
- BlueHeaven
Fighissimo ma costa un botto.
No black and white in the blue...
davvero bella...ma per ora...ho skippato...devo prima mettere a posto tutto e poi capire se ho spazio e dove....
Io invece ci sono dietro da parecchi mesi ormai.
Nel senso che dopo la sua commercializzazione a Gennaio ho passato tre mesi sul CAD a ragionare sul farle qualche "piccola modifica"; a Marzo l'ho comprata, e dopo un paio di mesi passati a ordinare qualche piccolo extra ho iniziato a montarla.
Adesso mi manca il tetto e parte del secondo piano, poi vedrò di aprire un topic apposito (se anche voi ritenete meglio) dove potrò postare le foto delle varie fasi costruttive evidenziandone le modifiche rispetto alla versione di base. In ogni caso è davvero imponente, bellissima, ma senza toccarla viene molto sproporzionata in quanto è molto corta, infatti per mettere dentro la ceto bisogna svuotarla! cosa inammissibile per il costo alla quale è venduta. In ogni caso è bella alta e ci vuole un bel po' di spazio (infatti ora dovrò inventarmi qualcosa perché non ho ancora capito dove metterla).
bellissimo !!!
Wbirillo, se pensi che riguardo a modifiche io la mia Ecco-1 l'ho rigirata come un guanto.
Portiere anteriori apribili, interni rifatti con 4 posti a sedere e la possibilità di farci stare tutte e 4 le MF, sotto il cofano ho strutturato il motore ed ora con calma sto progettando le aperture del cofano per l'appunto e del portellone dietro.
Postate foto ragazzi, postate
Sono curioso delle modifiche
Grandissimo Aokiji!!! mi fai venire una gran voglia di comprarmi un'altra Ecto e modificarla come hai fatto tu, ma credo che dovrei romperti parecchi le scatole per carpire i tuoi segreti Intanto vado a studiarmi come si inseriscono le foto perché non trovo più il pulsante
la ecto-1 vorrei vederla pure io... son curioso..... ahhhhhhhhhhhhhhhhhhhhhh i lego.................. mo non ne ho manco uno... se inizio guai!!!!!!!!!! ma che figata di gioco!!!!!!!!!!!! credo uno fra i migliori mai inventati!!!!!!
e stiiiiiiiiiiiiiiiika... complimenti.........davvero bella...........(la foto al buio è spettacolare......)
- Armand Kharas
minchia wbrillo, sei riuscito ad allargarla, che spettacolo! bravissimo!
ma le luci sono comprese già nell'originale o le aggiunte tu?
Magari fossero state incluse le luci....no purtroppo (o per fortuna) quelle sono un extra. Ci sono varie ditte che realizzano pezzi compatibili con i Lego, e queste luci fanno parte di un kit fatto appositamente su misura per la caserma.
Ce ne sono di tutti i prezzi, questo forse era il più caro ma è fatto davvero benissimo e soprattutto non richiede strane invenzioni per montarlo.
Peccato solo che non abbiano inserito qualche effetto sonoro, sarebbe statala ciliegina sulla torta
