Metamor-Force : Sentinel : Fire Dagwon (The Brave Command)
Re: Metamor-Force : Sentinel : Fire Dagwon (The Brave Command)
Nonostante non me ne freghi un tubo del modello, madonna che lavori paurosamente belli che fa la Sentinel
si ma con sti prezzi (42 mila yen) non si va molto lontano.Wamoo85 ha scritto:Nonostante non me ne freghi un tubo del modello, madonna che lavori paurosamente belli che fa la Sentinel
METAMOR-FORCE Brave Command Dagwon FIRE DAGWON
KAEN GATTAI (Blazing Combination)! Fire Dagwon!!
Fire Dagwon, the main combining robot from “Brave Command Dagwon”, is now available as part of the METAMOR-FORCE series!
By combining Fire Jumbo, Fire Stratos, Fire Ladder and Fire Rescue through Blazing Fusion, Fire Dagwon is formed! Using an original rendition to realize Fire Jumbo’s transformation mechanism, it becomes possible to maintain the form and proportion depicted in the anime even after fusion!
Bright colors and an abundance of diecast parts give the figure a heavyset finish! Impressive weapons like the Fire Blade and Lio Sword are also included. Recreate dynamic action scenes through the figure’s superb articulation!
It can combine with “Power Dagwon” (expected to start pre-order later this year) in the same series !
Honoo no Yusya (The Brave of Fire) is for you to own!
Item name: METAMOR-FORCE Brave Command Dagwon FIRE DAGWON
Materials: ABS, PVC, PA, POM, Die-cast
Size: Approx. 240mm (to tip of wings), Approx. 200mm (to top of head, including horn)
Accessories: Fire Jumbo, Fire Stratos, Fire Ladder, Fire Rescue, Fire Blade, Fire Blade blade part (Normal), Lio Sword, Lio Sword blade part (Normal), Articulated hand parts (LR), Lio Sword hand parts (LR), Display base, Base support parts
★Bonus Parts: Fire Blade blade part (Powerful), Lio Sword blade part (Powerful)★
《Bonus Parts Ver.》Official retail price for overseas: HK$2,500
*Bonus Parts Ver. is D4TOYS.COM, Sen-ti-den and Sentinel direct event exclusive for overseas, Sen-ti-nel Store exclusive for Japan.
《Normal Ver.》Official retail price for overseas: HK$2,370
(Shipping charged separately)
sentinel o non sentinel, questo è il problema
Prezzi come i Pose+ ma altezze molto inferiori qui siamo sui 20 cm.
Almeno Pose+ allo stesso prezzo fa modelli di 25/26 cm!
ryoma74 ha scritto:Prezzi come i Pose+ ma altezze molto inferiori qui siamo sui 20 cm.
Stiamo parlando della stessa pose che fa il goldimart con ali e lucine a 80000 yen ?
Comunque si in questo caso prezzo un po’ troppo alto m, ma rimane la scimmia
Vallindo ha scritto:ryoma74 ha scritto:Prezzi come i Pose+ ma altezze molto inferiori qui siamo sui 20 cm.
lo sapevo ti stavo aspettando.....che si fà? lo si prende?
voltron. ha scritto:Vallindo ha scritto:ryoma74 ha scritto:Prezzi come i Pose+ ma altezze molto inferiori qui siamo sui 20 cm.
Che domanda chiaro:) attenzione però che tipo il mese dopo arriva anche L amakumi e si rischia la vera mazzata
Il Goshogun, il Baxinger, il Baldios, il Braiger, il Sasuraiger non costano 80,000 yen e sono alti 26 cm non 20 cm.
ryoma74 ha scritto:Vallindo ha scritto:ryoma74 ha scritto:Prezzi come i Pose+ ma altezze molto inferiori qui siamo sui 20 cm.
I primi due sono usciti anni fa, il baldios sono 40000 se non sbaglio, il braiger effettivamente un ottimo prezzo, il sasuraiger sono tipo 53000 yen però vado a memoria capace che mi sia sbagliato. Da questa lista ci siamo dimenticati il ggg e il baikanfu, pezzi fantastici che però non costano sono costati 40000 yen, e il ggg probabile unico confrontabile con questa uscita per ingegneria e probabile costo licenza.
Detto questo pose plus è la mia azienda preferita con sentinel/flame toys ma da qua a dire che i prezzi sono migliori uhm ne passa. Tenendo conto che poi i sentinel prima di scomparire si abbassano sempre di prezzo per me sono sempre stato l’opzione di alta qualità al prezzo inferiore. Poi come detto sopra stanno alzando un po’ troppo i prezzi anche loro(però stanno alzando la qualità quindi boh ora vediamo come va i Linebarrel).
Non dico che i prezzi sono migliori ma sono migliori dei Sentinel in termini di prezzo/altezza modello.
Se 40,000 yen fai un modello da 20 cm io con 40,000 yen prendo un Baldios o un Braiger da 25/26 cm.
Che poi 40,000 yen sono tanti in ogni caso lo sono eccome!
ryoma74 ha scritto:Non dico che i prezzi sono migliori ma sono migliori dei Sentinel in termini di prezzo/altezza modello.
Miglior rapporto altezza prezzo i big size di evolution toys comunque stupidate a parte sarei molto contento se fossero 10000 yen in meno (sia sentinel che pose plus )
Se questo Dagwon fosse 25/26 cm lo prenderei ad occhi chiusi da affiancare ai Pose+ essendo fan dei Brave.
Ma 20 cm mi frena molto.
