S.R.C.: Great Mazinkaiser
Forum dedicato ai Super Robot Chogokin
Messaggioda ryoma74 » 23/05/2017, 10:23
Re: S.R.C.: Great Mazinkaiser
Messaggioda ryoma74 » 23/05/2017, 10:49
Dal Manga Shin Mazinger ZERO (真マジンガーZERO)
Great Mazinkaiser features a more detailed appearance similar to the original Mazinkaiser as well sharper looking armor with a few spikes adorning it including the crown and shoulders. The heat sink is shaped slightly differently with the ends pointing upwards.
Great Mazinkaiser
By combining with the Great Booster and having the Photonic Energy engines synchronize with the Black Boxes, Great Mazinger is able to change into a stronger form that includes armor made of the more powerful Super Alloy New Zα and has increased performance. This form allows Great to fight with Mazinger ZERO even with its Higher Dimension Prediction ability activated. After a couple of timeline changes, this form seems to have been erased from existence.
Attacks
Turbo Smasher Punch: Spins the forearms before releasing it through rockets to pulverize through even the thickest metals.
Gigant Missile: Releases a missile out of the naval cavity.
Great Tornado: A stronger version of Great Typhoon that features much more force and concentration.
Great Blaster: A stronger version of Breast Burn enough to equal out the power Mazinger ZERO's Breast Fire.
God Thunder: A higher voltage version of Thunder Break
Kaiser Sword: Uses a longer and stronger sword for combat.
Korovev
Messaggioda Korovev » 23/05/2017, 12:17
Avrei preferito il regolare Shin Great dello stesso manga. Questo non è neppure male, ma sicuramente evitabile, visto anche il prezzo a cui lo proporranno
Geddy
Messaggioda Geddy » 23/05/2017, 12:21
EVVVAAIII!!!!!!!!
Geddy
Messaggioda Geddy » 23/05/2017, 12:22
Korovev ha scritto:Avrei preferito il regolare Shin Great dello stesso manga. Questo non è neppure male, ma sicuramente evitabile, visto anche il prezzo a cui lo proporranno
ARRIVERÀ ANCHE QUELLO
Messaggioda SchumyGo » 23/05/2017, 12:28
aspita questo si che è un Great decente! in coppia con lo Z è veramente notevole... :shock:
Actarus77
Messaggioda Actarus77 » 23/05/2017, 12:35
Dalla foto nn si vede bene,ma nn è troppo smilzo rispetto al manga?
green terror 72
Messaggioda green terror 72 » 23/05/2017, 12:39
Azz caruccio!
Haran
Messaggioda Haran » 23/05/2017, 12:53
Ma a quanto sta???
Haran
Actarus77
Messaggioda Actarus77 » 23/05/2017, 12:55
12960 ¥ al cambio attuale 103€
Ottobre
Messaggioda ryoma74 » 23/05/2017, 13:05
Sarà un Tamashii Web Shop
Spriggan
Messaggioda Spriggan » 23/05/2017, 13:16
che furbacchioni, hanno riciclato almeno mezzo Mazinkaiser
Actarus77
Messaggioda Actarus77 » 23/05/2017, 13:23
Sì compreso i piedoni
McTurbo
Messaggioda McTurbo » 23/05/2017, 15:07
Bellissime le Ali rovesciate. Mi piacciono un sacco. Odio quelle di Pipistrello.
Actarus77
Messaggioda Actarus77 » 23/05/2017, 15:14
Però così sembra ke gliele abbiano incollate al contrario..
Torna a “S.R.C”
